Lawn Ranger Don
- Sep 13, 2022
- Threads
- 2
- 45
Can you disconnect the meter? I can on my Toro.
One way to look at it, but it's simpler just to remove the key. Even if the hour meter is disconnected, you still have things like the carburetor anti-backfire solenoid to deal with, and item that likely consumes more battery juice than the hour meter.Can you disconnect the meter? I can on my Toro.
We have a master switch in the motor coach. Same effect. Only item that remains attached is a solar panel on the roof.One way to look at it, but it's simpler just to remove the key. Even if the hour meter is disconnected, you still have things like the carburetor anti-backfire solenoid to deal with, and item that likely consumes more battery juice than the hour meter.
I worked heavy highway for many years. Many of the pieces of heavy equipment I dealt with -- graders, bulldozers, excavators, etc. -- had "master switches," which were heavy gauge keyed switches that completely isolated the batteries from everything when they were in the OFF position. It was more of an anti-theft and anti-tampering device, but it also helped keep the batteries alive.
the old units did only work when the engine was running, not sure when they changed that.So now my hour meter shows over 24 hours instead of the 4 hours is should. I don't suppose I can turn that back? It was a stupid thing to do although I had previously thought that the hour meter only registered time when you were driving it or mowing. Nonetheless, I should have checked the key before I locked the shed doors.
