- Feb 19, 2020
- Threads
- 111
- 12,264
Are referring to the connector shorting strip of that Delta 6444 switch?
If so then it is likely it was not un-shorting when connecting the connector to the switch. There two styles of the 6444 swithc that would work on this mower. One is for with the shorting strip and one is not. That shorting strip just prevents the operator from simply removing the connector to by the seat switch. On unit the shorting connector the connector must be fully plugged and held tightly to the switch.
