PTmowerMech
- Apr 16, 2018
- 387
- 2,954
13WQ93KP011 Super bronco
Running at full throttle, battery is charging over 13v. Getting about 14v in and out of the PTO with the switch pulled/on. (almost nothing when switch is off)
But it's not engaging. The ohms are 0.00 on the tractor. So I'm thinking it's just a bad PTO.
Is there anything else that needs to be checked before I make that call?
Also, can you check the ohms with the PTO on the tractor? Or does it being grounded to the crankshaft affect that reading?
