Hammermechanicman
- Jan 10, 2020
- Threads
- 56
- 3,537
The ms250 is a good saw for most homeowners. The chain that comes on the saw will be an anti kickback semi chisel chain. If you look at the chain you should find either a yellow or green painted link. Green is anti kickback safety chain and yellow is non safety. "Green" chain is a little slower cutting that the older style of chains. Semi cheisel cuts slower than full chisel but dulls easier. Stihl's fastest cutting chain is the RS line. Cuts fast dulls easily and non safety. Take your pick but keep it sharp.
