FR691V with no ID sticker
PTmowerMech
23hp on a Gravely ztr.
I'm trying to find the right carb for this, but I'm not finding any numbers anywhere. I can see where the sticker used to be. Does Kawasaki stamp anything on the engines?
Mower King
It depends on how old this eng/mower is but, Kaw has started putting another eng ID sticker inside the air filter area.
MParr
Can you find the Gravely model number and serial number? If so, go to the Ariens or Gravely website and plug it the numbers. That should give you any information that you need.
PTmowerMech
Must be older than that. The only sticker is Kawasaki label on top. And only gives the FR691V.
Might have to clean the block to find it. Could be covered up under an oil slick.
PTmowerMech
I can't find a place to add the serial number. Am I blind? Or is it hid?
PTmowerMech
You go thru this link on that page.
or just use this link.
https://www.ariens.com/en-us/manualsdownload
and you get a page like this:
Yeah, that doesn't really give me the actual engine number from this particular mower. Just a list of engines that was used on these mowers. (and a few others). Putting the M# and Serial #, gave me two different manuals. Neither of which had my specific engine. Nor did it give me a part listing for anything on this engine. Mainly parts diagrams and parts list for this mower.
Good info though. A ton of good info.
MParr
Give us the model number and serial number and see if we can help you.
