PTmowerMech
- Apr 16, 2018
- Threads
- 440
- 3,392
First there is no KT746 according Kohler. It is a KT745.
Apparently no else has seen this before.
You have checked only three of the four bearings directly related to crankshaft. If it is what I suspect is wrong you're going to need to short block it if the owner of the Husqvarna mower is willing to do so. $$$$. Other wise another engine. $$$.
Now with that I going back to data harvesting the forum.
And correct you are, as usual.
Ha, when I finally got the crankshaft out, I was expecting roller bearings. So it looked like everything melted. But soon realized it was just the crankshaft machined to fit the hole.
I don't understand why there's no oil journal for the top bearing? Seems that would be a better place, so the oil could get the top and the bearing below. Or even better, two journals.
In fact, there should be roller bearings with oil journals. At least you wouldn't have to replace the whole block.
Thanks for the info, man. You really are a necessity around here. Even if you do get a little snappy sometimes. LOL ??
