- Sep 24, 2017
- Threads
- 288
- 6,901
No, that's just Mark Sims.......There is a god.
Maybe this: "Sciatica" refers to pain that radiates along the path of the sciatic nerve, which branches from your lower back through your hips and buttocks and down each leg. Typically, sciatica affects only one side of your body. Sciatica most commonly occurs when a herniated disk, bone spur on the spine or narrowing of the spine (spinal stenosis) compresses part of the nerve causing inflammation.I don't know what I did to my back, but since before Christmas of last yes, it's been giving me fits. And it's SOO easy to flare up. When it first started hurting, I swear, I couldn't even put my socks on. Much less tie my shoes. When I got able to go to town, I had to go get a pedicure because I couldn't reach my toenails to cut'm.
And now, all of my shoes have to be slip ons.
Most days now, everything starts out good. And I can do just about anything. I get used to that, and BAM!!!!!!!! I do something like trying to lift something heavy, or even reaching down up pull up my sock, and it's over. No rhyme or reason. Just when it wants to.
After mowing that yard for two days, I can feel it coming on. I felt it about an hour before I was done today. It was getting tender.
Probably has dull blades. I have them sharpened. It’ll make a big difference in the tall grass
Put a puffer seat on the Gravely. Likely cheaper than trading.
Well, everyone, who complains about mowing uneven property, should come here and try mine.
This is why I sold 2 ZTRs. 52'' and 60''. Though they mow well and were great fun to do donuts around trees, after about an hour doing mild storm waves of grading, on my lower 3 acre lot, head felt like as if it were disconnected from the body. Nauseating.
This is how I ended with UTV towing a flail. At least, in UTV, I have normal seats and four corner long run suspension. And, price combined for both, it is still half the price of say 60 inch ZTR with four corner suspension.
As of lack of traction .... the first thing I do on each mower I have is to ditch turf tires and replace them with ATV tires. THEN you have traction. As I have hills too. It's HELL to mow every time. I have to edge fence with rider, 52'' Cub, as UTV with flail does not go into tight corners and, after about a year of edging 6 acre property, steering rods on that Cub bent so much, from hitting high points with the front wheels, that they started pointing about 15 degrees in opposite directions.
