Question for those that have dealt with the rear adjuster issue. I have just finished (hopefully) replacing the right side adjuster and it took way too long, most of the time was dealing with moving inside 25mm circlip out of the way.I have two different Channellock snap-ring pliers (medium 927 and small 926) and it was a struggle.  My pliers worked well getting the 12mm circlips off. The replaceable pins for the Channellock tips seem to be too small for the large 25mm circlip openings. It seems the 929 (larger model) has thicker tips that may work better. Is anyone using a different brand that works in removing the circlips?
I did not stand my mower on the front nose to perform the service. Instead, I used a lift table and jacked up the rear so I could do most of the work sitting.
Again so far, the only complication is the inside circlip.
I certainly do not want to battle with circlip in the future so if anyone can share their experience, please let me know.
Well, got to stop here, I am off to replace the left adjuster.
