Now that the drive motor controller has been replaced, it runs for about 30 minutes and then stops, yet everything else (lights, mowing deck, beeper, etc) works. I've done some testing and concluded it's an overheating issue.  The reason I think this is because if I leave it sit for about 40 minutes it will work again.  No idea what is overheating, if it is the drive motor controller or the motor, but I feel like that is about all it could be since everything else continues to function.
Anyone else having symptoms that point to overheating?
