Grhopper
While moving the wire harness around I started to hear the low oil pressure tone. It only sounded when I had the harness in a certain position. I began testing the fuses for continuity. They all looked fine visually, but the top one didn't have continuity. I replaced all 3 fuses and the mower is running again.
I still have the issue that I can't start the mower with the switch. I replaced the key switch and the PTO switch. I also tested the seat switch, 2 arm switched and the break switch for continuity. They seem to be working fine. Someone I spoke with said that I probably have a short on a ground wire somewhere. The only wiring that I see that has an issue is the 12v accessory port. It looks like it was cut off. Would that cause issues?
Reminder, to start the mower I turn the switch to on and jump from the positive terminal on the battery to where the blue wire connects to the starter. After the engine starts I disconnect that jump wire and cut the grass. Turn the switch to off when done.
