I went to Lowes since it is up the street here is the link. I am sure HD has this to in a different brand. It is approx. 1/4" thick. I have more than enough and I just cut a strip to fit. Trial and error.
			wondering how this is working? i bought a used hrr216k9vka last season, used it with out the self propelling feature. tore it apart last week and found one of the wheels seized. tried to order updated parta from honda but back ordered until end of april. while I like the needle bearings not sure if the shaft will wear prematurely. did ypu ever think to use some bronze oilite bushings?
Bronze bushings would work too. They would also need greasing, will wear and most likely need to be replaced every few years. I did get my sealed bearings today and taking them to the machinist tomorrow. They are small bearings but I do believe they will work the best. You did the right thing by replacing the grease. My needle bearings came dry. There are lots of options here and all look very promising. I didn't mind re-lubing the bushings every year but it gets old fast and want a more permanent repair.Bronze Oillite bushings are bronze bushings impregnated with oil. As the axle turns, it is lubricated by the bushing. Interesting concept and food for thought. Honda would have been much better off using those rather than the cheap plastic bushings they opted for originally. Are they better than needle bearings? Would bronze bushings (self lubricating) hold up for the long term? I picked up some needle bearings from Amazon (1/2"x11/16"x7/8"). They were packed with a clear grease which looked a lot like petroleum jelly. I flushed that grease out and repacked them with Redline CV-2. If these needle bearings fail, it won't be because of cheap grease not protecting them. OIllite bushings: https://www.amazon.com/uxcell-Beari...?dchild=1&qid=1592859615&s=industrial&sr=1-26
Westman, take a pic and post pleaseI got my parts back from the machinist today. Needle bearings pressed into the new adjusters (L+R). I'll be starting tomorrow on disassembly of the rear wheel assembly. I'll be sanding down the axle and smoothing it out, taking my time. I'll report back and provide some pics as I progress...
Here is the pic of that spring I found under the mower when I finished. I have no idea where it came from, but it must have come from the mower, some where. Anybody have any idea?
