cambre, read this.  This is from another post that has a 'similar' problem.  It's a Kubota gas mower, but the problem is similar to yours:
Sharing this public service announcement for what it's worth as my local dealer says they've seen it on a number of the Kommander ZT's.
I have a 2013 ZG124E with a 48" deck. Last fall for no apparent reason I could think of, it started stalling & running rough. Like it couldn't get enough fuel. It would run okay for 5-10 under PTO load after I started and would stall. After that, I couldn't keep it going for more than several seconds. When I came back to it the next weekend, same thing.
I tried:
- Cleaning the carb
- Adding Dry Gas
- Replacing the fuel filter
- Replacing the air filter
- Checking the plugs
All with no luck. After a conversation with the service guy at my Kubota dealer, he said it was likely tube mechanism going into the gas tank. There is a 90 degree bend which apparently allows debris (grass) to get stuck, limiting fuel flow. After it sits for 10 minutes or an hour or a day, gravity pulls the debris back into the tank where the cycle can start all over. How debris is getting in there is a mystery.
The fix is a new tube to insert into the gas tank which has a mesh screen on it. Cost me $18.
Took literally 2 minutes to install and the first time I started it, it ran as strong as ever.
Hope this saves some of you some time, money and headache!
[/QUOTE
			Here's the thread:
https://www.lawnmowerforum.com/thre...ms-sputtering-stalling-etc.47223/#post-359422
Look at the debris in that tube.  Yours may have a similar fuel pickup.
I won't be around until late afternoon if you have questions but there are plenty of other people a lot smarter than me on here.
I pulled tube from the tank, blew it out with compressed air, nothing came out. I blew out the hose going to first filter, all clear. That was good post you sent. Thanks very much.
