upupandaway
- Jul 3, 2015
- Threads
- 38
- 636
IIt will start if I spray carb cleaner in the carb and pull the cord. And, it will continue to run fine until I turn it off.
JC, If u take out the air filter do u see a brass "flap"(the choke) closed or is it open? I ask because pictures of the model that come up(http://newhavenpower.com/Toro20333.html) have the briggs engine which might have the auto choke that is instead stuck open making it not choke to start normally thus your problem.
