Keeps running but won't start when pulling the cord.
BlufftonJim
  • / Keeps running but won't start when pulling the cord.
I have a Toro 190cc. It won't start when pulling the cord.
It will start if I spray carb cleaner in the carb and pull the cord. And, it will continue to run fine until I turn it off.
But, it will not start by just pulling the cord. I must spray the carb cleaner to start it.
Please post the mower model and serial numbers, so we can see what you are talking about.
BlufftonJim
Yes, the Toro is a 20333 Personal Pace. Serial number is: 10 02 16 56 60304. I can take and add some pictures if needed.
That is not the serial number, please check the decal on the deck. That model used two different engines.
BlufftonJim
I took that number off of this sticker.
That is an engine number which I don’t know how to decipher. I use the one one the deck. 20333 will be on top of decal and serial number will be below it.
BlufftonJim
This is the only other sticker I could find.
Nope, that is the bar code. Next to the rear adjuster or under the bagger cover.
BlufftonJim
Okay, that info helped! Here it is.
Ok, that was what I needed. Know that I know which carb we are dealing with, I think your problem is a swelled float needle seat. This is not allowing enough fuel to enter the float bowl, which will not allow it to choke or prime properly. I suggest you clean and rebuild the carb with these parts. Rebuild kit part number 498260. Here is the procedure I use and recommend. Hope this helps.
Needle and seat replacement.
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. Next check to make sure that the float does not have any liquid in it. If it does, replace. If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: On the side of some Tecumseh carbs you will find a plastic cover. Under this cover will be an idle jet. Remove it and check to see that the jet is open both horizontally and vertically. You should be able to push the old float needle wire through the vertical opening.
