Repair Kubota
cambre
My Grasshopper with 25HP diesel engine runs about 30 seconds then dies. A new fuel filter did not help. Does this engine have a fuel pump? Thanks for any answer.
It will have an injection pump for the fuel injectors.
Will need all the equipment numbers including the engine make and model numbers.
Most Kubota’s have two fuel filters, in-line very close to each other. Don’t know if your Grasshopper has two?
cpurvis
Usually when a diesel dies from fuel exhaustion, there is no restarting it until you re-prime the system. Did you re-prime after changing the fuel filter?
Hammermechanicman
Most kubota's have 2 fuel filters and an electric fuel pump and then the injection pump. It sounds like the electric pump is failing. I have seen that symptom on kubota powered equipment a few times and it was always the electric pump. Be careful if it is the electric pump. Running the injection pump with no fuel can damage it.
cambre
Will get them posted
cambre
All I see is one filter. When filter is changed does air get into fuel injection system? I have changed the filter before and did not have to bleed air out of fuel system. I will bleed system, easy enough to do to see if it helps. Thanks for answer, you have helped me before.
cambre
No but I will, thanks.
cambre
cambre
Has no electric fuel pump. It's a diesel, has fuel injection. Thanks for answer.
