Position of butterfly valve is wrong. Can you let me know how to adjust properly?Make sure choke cable is working properly & not broken, opening & closing butterfly valve.
Will try asap. For the moment grass is done with electrical device. Thanks for replyFlap nearer to the engine or flap nearest the air filter ?
does it run nomally after you start it ?
doe the govenor work as it should when you go into thick grass ?
