Starting problem
topi
Have b&s12f802 mower engine. Can start only after manually move the carburator butterfly flap. Even after engine did run and shutting down again.
mechanic mark
Make sure choke cable is working properly & not broken, opening & closing butterfly valve.
Flap nearer to the engine or flap nearest the air filter ?
does it run nomally after you start it ?
doe the govenor work as it should when you go into thick grass ?
topi
Will try asap. For the moment grass is done with electrical device. Thanks for reply
