- Nov 29, 2014
- 24,995
All the solenoid does is connect the 2 heavy terminals on the top.
So one of them has the power from the battery and the other has the power cable to the starter.
It is turned on & off by the small terminal at the base being given 12V ( VIA THE CRANKING CIRCUIT ) .
The other half of the trigger is the bolt holding the solenoid down that makes the ground half of the trigger circuit.
If the solenoid is bolted onto something that is plastic then there will be a ground strap to one of the bolts.
On the same post as the wire from the battery should be power feed to the mower, usually a red wire with a fuse in it that connects to the B on the battery,
No wire should have an aligator clip on it so that wire might be a power take off to run an accessory .
You need to follow it back through the loom and see where it goes to
