- Nov 29, 2014
- 64
- 24,702
[QUOTE="Andi, post: 350360, member: 100681"
I jumped B to S. Had voltage on the yellow lines, including at solenoid, no voltage on white wires at the brake, PTO or either lap switch.
[/QUOTE]
I am having some troubles following what you are doing but the above is exactly what should be happening.
The starter should also crank if the yellow wire is hooked up to the solenoid.
You should only have power to one heavy lead on the solenoid till that yellow wire goes +.
The solenoid is just a switch like any other realy except it can handle 200 Amps.
Now to clarify things, does your mower have a remote solenoid or one that is piggy back on the starter which most Kohlers have ?
[/QUOTE]
