Richie F
 - Aug 8, 2019
- Threads
 - 25
 - 299
The purpose of this message is to (hopefully) provide some clarification with respect to the comments about diodes, rectifiers, AC and DC. You noted correctly before that the voltage coming from the stator of the engine is AC. Some stator assemblies incorporate a single diode in the harness to provide 'half-wave rectified' AC to the rest of the machine. Some older engines incorporate two individually replaceable diodes to do 'full-wave rectification' of the AC to the rest of the machine. Some embed two in a harness. I'm pretty sure that your Scag's Kawasaki engine uses a 3 terminal 'voltage regulator' to convert the AC stator voltage to the DC used by the machine. AC from the stator goes 'into' the regulator on the two terminals labeled AC, and the rectified or DC output comes from the terminal labeled B+, and ground. I'm pretty sure the wire labeled 'rectifier' on the diagram goes to that B+ terminal of the voltage regulator on the engine.
So, what's the purpose of the diode located across the PTO coil? Well it's merely there to provide protection to the regulator located on the engine. It has absolutely nothing to do with converting AC to DC for operating the PTO. It's called a 'flyback' diode. Why is it needed? Whenever a DC current is flowing through a coil, and it is interrupted by the opening of the PTO switch, it creates a huge voltage spike across the coil. I won't bore you with the engineering reason why. That voltage spike can damage the regulator on the engine because it 'sees' or is exposed to the spike. The semiconductor devices embedded in the voltage regulator can be damaged by this kind of high voltage spike. The diode across the PTO coil absorbs the spike by providing an electrical path around the coil, and the regulator on the engine never 'sees' the spike. The fact of the matter is that it is NOT required to operate the PTO. You can disconnect it and operate the PTO just fine. The chance you take is you damage the regulator when you open the PTO. Many machines don't use a flyback protection diode, particularly ones that have batteries. A battery also absorbs that spike. Under normal operating conditions(PTO on), the voltage present on the cathode side of the diode is always positive with respect to the anode and as a result, there is NO current flowing through the diode. That's why it's not necessary for the operation of the PTO. It's for protection only.
I know you said you checked the diode, but understand if this diode were shorted, it could produce the condition you are seeing. I'd still suggest the following quick test. Disconnect one leg of the diode and then start it. Hit the PTO and see if it still kills it. BTW, the chances of this one test causing damage to the engine voltage regulator are very small. That device is robust and it's the repeated exposure to voltage spikes that causes semiconductor breakdown leading to part failure.
FWIW... Let us know how you make out!
OK thanks for some education on this problem.
If you look at either wiring diagram/schematic posted you will only find one diode in the harness to the clutch.
From the parts break down of the Kawasaki FS481V engine there is only a one wire stator with no 3 terminal voltage regulator.
https://www.jackssmallengines.com/j...s22-4-stroke-engine-fs481v/electric-equipment
So the diode should be a fly back?
This is the way I tested it:
Engine not running.
Disconnected the deck harness plug to the handle switches.
Unplug the connector at the clutch, using my VOM set on the diode symbol, tested the two wires on that plug. Went from A to B one way and it was OL. Changed leads on A and B and got zero volts, showing a voltage path.
I would think if that diode was shorted I would see zero volts in both directions.
Correct me if I'm wrong.
This machine is a pull start and does not have a battery or starter motor.
I'm curious how a single wire wound stator can produce a DC voltage to operate the electric clutch with no regulator ?
I want to make a break out T and see what the output will be. AC or DC.
I do have a sister machine with no problems. I can test it's single diode or install that deck harness on to the problem unit.
I'll leave you with this information.
