Richie F
 - Aug 8, 2019
- Threads
 - 25
 - 299
I'm working on a model SW36A14FS
s/n J6100114
The owner of this machine has disconnected/by passed all safety switches.
With the engine running when the PTO is engaged the engine shuts off.
Unplugging the ground wire for the Magneto the PTO will function properly.
I realize something is still in the circuit to ground out the Magneto when using the PTO switch.
Both harnesses are in good shape. No chafing anywhere.
I tested the resistance of the PTO coil and have 3.3 ohms.
Also tested the diode and it's good.
I do have the wiring diagram for this machine.
Thanks
			s/n J6100114
Thanks
