- May 6, 2010
- Threads
- 51
- 11,393
I don't know of any small 4 cycle engine that calls for a non-detergent motor oil. Some of the early small engines called for non-detergent because the dipper type oil lube systems was supposed to cause foaming of the detergent leading to lack of lubrication. I believe non-detergent is still recommended in oil bath air filter systems since you want the dirt to settle to the bottom.
Non-detergent is still used in pressure washer pumps maybe due to foaming concerns or maybe you want any impurities to settle to the bottom of the washer pump.
