Thanks Mr. Mower. Soon as I sand off the ugliness and give the outside a nice smooth coat it won't look bad at all. By they way, works like a charm. Much stronger than the over the top deal as the leading edge is re-enforced.
Another way to have done that would have been to take a piece of 10 gauge flat stock, welded it below the front and rear opening after cutting out the bar. Would buckle slightly if you hit something hard enough. But then, that would still keep the front from folding quite so easily.
Thanks again.
Max
Mr. Mower,
I have not as of yet. I have several other modifications to do videos on which include: Anderson quick connect battery connector, adding an eight circuit fuse panel in order to add things such as front and rear lights, motorcycle type flashing lights in the event some idiot uses this particular mower after dark also in the event they are mowing right next to the street. I don't know any such idiots, thank goodness. If so, I'm going to knock on their door and ask them kindly to put that damned mower away until after breakfast. lol. Adding a 12 volt power socket, and a few other fused circuits in order to make sure nothing is left unprotected.
View attachment 38628View attachment 38629View attachment 38630View attachment 38631View attachment 38632
Here is what you get with the deck modification kit. Nice heavy duty plate and a bag of bolts. They want you to drill several 0.41" holes. Had to get out my calculator - works out to be a 13/32 drill bit (0.40625)
I am trading in my Raptor SD for a 2017 X-One, so I have no need for the RSD deck modification kit. This kit lets you cut off the lower bar that goes across the deck discharge opening. I cut off the bar on my deck, but before I could install the kit, sent the deck in for warranty replacement due to peeling paint. While in for warranty work, the dealer let me demo a lightly used X-One and I am going to keep it. I paid $70 for the deck modification kit. Comes with the heavy duty plate shown in the pics, plus all bolts, hardware and instructions. I paid $70 for the kit. I am selling it for $55 including shipping. PM me if interested. Thanks!
