Boudreaux In Eunice La.
- Jul 22, 2017
- 2,154
Bert has some great advice for you right there........ It is a great way to learn about these engines......
First thing you do is check the oil...... If it doesn't have any that's your culprit... I took one in a while back and it had a broken rod 3 pieces in the bottom of the sump....
If you had the govorner wide open holding it with a wire tie or a string that will do it to..... OVER revving will cause a rod to throw and break the block.........
I have seen that tooooo many times in my lifetime.............
