If it has a hole in the side of the block then it is deceased.
Deceased engines are the perfect things to pull apart cause no matter what you do you can't make it any worse.
So pull it down, note how everything goes together and put it back together a couple of times.
Sort of a jigsaw puzzel for big kids.
While it is apart, pull the piston off the rod then pull a ring off the piston.
use the bottom of the piston to push the ring into the bore & measure the gap at 1/2" intervals so you can work out where the bore is worn.
All good practice on a body that is already dead.
Look closely at all of the bits and try to work out why it broke.
Put some photos of the con rod, piston, inside & out, gudgeon pin up here if you like and ask some of the techs to explain how to read them.
It is one thing to be able to remove & replace damaged parts to get an engine running.
It is entirely a different thing to work out why it failed so the rebuilt engine does not suffer the same fate.
