Hello I have a 2007 briggs and Stratton yard machines mower not sure on the model number I can get it later.I have tried almost everything to get it started I have replaced the plug I have sprayed starting fluid
This model is one of the mowers that does not have a carb it has the gas tank that is attached to the side of the mower and does not have a carb
At least I can’t find it
Do you have any suggestions
It has 60 psi compression and the spark is sparking
I just can’t seem to get it to fire
Also I have a mower that seized on me recently I had it running this past Sunday and I went out to pull it yesterday and the engine is seized any suggestions on how to prevent this it has oil but is stored outside the weather was not cold but I’m not sure if that was a factor if you have any ideas why it seized or how to prevent or fix it that would be great both are the same brand and both are Briggs and Stratton
Thanks
Thanks
