TORO Recycler losing oil - not from oil tube
idriv442
I just purchased this Toro used. I t was cleaned and dried by previous owner. I brought it home and filled the gas and topped off the oil. About 20 minutes goes by using it and I see oil leaking out the side of the motor. I have attached pictures. Do I need to pull it apart or is this an easy fix. I tried searching, but mostly found oil tube leaks.
Motor: Tecumseh 195cc
Model LV195EA
The best way to find a oil leak is start with a very good cleaning. Then run it and keep watch around the area of the leak to find it.
And while it is till damp a good dusting with talcum powder or something similar.
Let it dry off so when you start up you will have a nice white coating for the oil to bleed through.
It was clean and dry to start. The oil is coming from above the threads in the picture.
