Ok, so I took the Starter Bendix gear assembly apart, found no problems with the hardware, other than some minor wear (expected). Parts work fine when manually advancing gears up the threads, so all appeared ok at first glance.
What I found is that while the parts are fine and lube works to allow manual lifting of gearset, centrifugal forces are unable to spin the gear assembly upward because gear assembly seems locked to base during the initial startup spin.
Some additional investigation shows that some other knowledgeable folks recommended NOT USING any wet lube on thread and bottom gear, instead using a DRY LUBE. Since the parts looked fine and I did in fact have wet lube on gearset, I cleaned off the WET LUBE and used DRY LUBE instead, and now the assembly floats-up and engages the engine flywheel gear. Success in this regard!
However, when I turned-off engine via the ignition key, the starter continued to remain engaged and turning (although I thought I observed the spring successfully forcing the bendix gear back down at one point). I have not yet replaced the Solenoid. Does this continued weirdness on behalf of the Starter help prove that the Solenoid is indeed defective, or could this be yet another facet of the Starter that might still be failing?
-David
-David
