O2Man
I experienced an electrical short 3 or 4 weeks ago, while running, that sent a jolt up the throttle cable and shut it down immediately. Since then, it will not turn over or start from the ignition switch; however, I can get it to turn over if I "hot wire" either the wiring harness that plugs into the ignition switch, or the starter solenoid posts, but even under either of those two circumstances, it will not fire, only turns over.
I have replaced the ignition switch and the pto/seat relay, and have tested all switches for continuity, and they all have continuity when they are supposed to, so I am thoroughly confused and have no idea what to look at or check next. Any help or guidance would be greatly appreciated.
