cord retracts but come back out while mowing
amatuer
i own an old kmart mower with a briggs 3.5hp motor. i just had the spring and pull cord replaced but this problem still persist. the cord retracts fine but once the motors running it comes out and makes a horrible sound anyone might know whats causing this?
KennyV
In the center of the ratchet device attached on top of the engine, there should be a round plug with a small hole in it. that needs to have some lube... ATF is the best any brand any kind... :smile:KennyV
may also have to remove the starter ratchet clutch assembly and polish the extended part of the crankshaft because lubing alone sometimes doesn't fix it.
jeff
And, if the above fixes do not work, you may need to replace the starter clutch assy.
Briana
Hey there! WELCOME to LawnMowerForum! :biggrin:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
RobertBrown
ATF means "automatic transmission fluid"....in case you did not know that:smile:.
KennyV
Oops... good catch, some folks may not know that.. thanks. :smile:KennyV
