Would definitely be cheapest way to go  but the switch actual protects against low oil pressure which could be caused by problems other than just low oil. So I am going to replace it.
Richard
			Richard
Would definitely be cheapest way to gobut the switch actual protects against low oil pressure which could be caused by problems other than just low oil. So I am going to replace it.
Richard
Richard
Richard
I don't think your engine has any oil pressure, it's splash lubricated.
That switch is for low/no oil.
My apologies to the group (and to Briggs & Stratton), I have discovered since starting this thread that the engine may be a 7.8hp "Generac" model. In any case there is a B&S parts listing I got from the Sears website which does list an 8psi pressure switch (not a level) even though I can't find an oil pump in the parts list (?????) or parts diagram. And the switch definitely appears to be a pressure switch, at least from the outside. My replacement arrives tomorrow so I'll know for sure after I do the exchange.
I cannot find an engine model number on the engine. It was the Sears part listing that led me to believe the engine was a Briggs. But photos I've looked at in Google lead me to believe it is a Generac. The two are so close together in size etc. it's hard to tell. Very confusing !
Richard
