Craftsman riding mower
DRM1
Starter turns over the engine about one turn then stops. Turns over engine fine when the spark plugs are removed.
reynoldston
Bad battery, poor battery cables or connections, starter brushes worn out, starter solenoid. Sounds like you are losing amperage some place???
mechanic mark
Post your tractor model number from under seat as well as all numbers from engine data plate. Check oil level on dipstick, make sure its on full mark.
DRM1
It's a 917.272280. Thanks.
Fritzm
Which fix worked, valve adjustment, starter motor brushes? I just joined this evening and I am having the exact problem with my Craftsman riding mower. Any help would be appreciated. Dumb luck I found you on my first try having the same problem.
DRM1
Adjusting the valves did the trick.
