twall
I'm not the technical guy to ask :laughing:but it does do both. Simply saying it articulates in the middle would not tell you that it actually does flex/oscilate in the middle. It would only say that the two parts turn independently of each other on a horizontal plain. But you could still have an overall solid frame. Downside is that if your front left tire goes up on a curb, then your lifting off your back left tire from the ground. So your decreasing your traction and stability. The oscilating part allows it to flex in the middle or on a vertical plain so all 4 tires can stay in constant contact on the ground. If that answer isn't satisfactory then I can ask engineering on Monday, then get ready to read a book :biggrin:
:laughing: No, you'd need to ask advertising.....as why they just didn't say "pivots both laterally and Horizontally"..........
But, I don't need a book.......like I said, I was takin a poke........cause this is the only action here tonight....:biggrin: Watch me fade away if/when the rest of the forum wakes up! laughing:
