Joe
Then my next recommendation would be Craftsman hand tools. They, for the most part, are top quality tools. However, I have had less than good experiences with their screw drivers, the tips will deform quickly.
I am retired, will never need my tools professionally again. My brother lost (or sold) about 60% of my tools I had acquired, but even now, on a fixed income, I am going to hunt down the snap on truck again, and buy a set of their screwdrivers.
I worked on transmissions in the late 60's and then went to work for Uncle Sam for three years. After that I went back to school and got into air conditioning and refrigeration, 6 1/2 yrs total of service and repair work, again using tools every day. using that little 1/4" drive set nearly every day of it, after that I got into Air Traffic Control, and was there for almost 27 years before being forced to retire (for max age).
When I worked for the AC company, he had a sign in the office that said something to the manner of, "You can always get your home heating and cooling system work done for less, and it may turn out to be quality work. then again, it may have to be redone, because the quality wasn't there and the system soon broke down again. You may spend, what you call, "too much" with us, but you will never have to spend it again. So, will you spend a little first, then a lot later, or spend a bit more up front, and never spend it again?"
Our company backed up every word of that statement, and back on topic, so does Snap On tools.
Each person has to decide how much they want to spend. If you're 70 years old and hang a few pictures now and then or fix a broken faucet ever so often, then it doesn't much matter. But if you're in your 30's or 40's and like to fix things yourself, you will be amazed how much easier a job becomes with the tools that fit. Ever struggle with a stuck phillips screw only to bugger up the opening inside the head? I can almost guarantee you that most of the damage came from a poor screwdriver tip.
I do a lot of hobby work at home and have a mix of tools, and I can tell you most of my frustrations with tools come from the cheap ones. I still repair my own tractor and mowers, and to a degree my vehicles. HF hand tools are mostly crap. I have some, and they do OK, but what a buyer has to think about, is, if I only use it once a month or so, but when I use it, if it breaks, will it be a BIG PITA to go replace it? If not then HF hand tools will most likely suffice. I have a fair number of their power tools, and do have to replace them, but they work pretty well most of the time.
My most frustrating power tool, has been the bench grinder (mounted on the stand they sell). The grinding wheel were so out of round that it will walk itself across my shop floor, unless I hold my foot on it.
So like anything, buyer beware. Money's not getting easier to come by, and with huge inflation right around the corner, spend wisely.
