Buying Advice Harbour Freight
KennyV
... Always felt Snap-On was way way overpriced, like Deere...you pay a premium for the name. Tractors I pay a premium for, but not tools.
If you work using Snap On for a while ... It's tough going back to anything less, they even feel nice in your hands, the alloy is perfect as is the fit ...
Mac is also a fine hand tool line...
That said, I do buy abrasive cut off wheels at HF...:smile:KennyV
LandN
The only issue that i see with snap-on and mac for a homeowner is you have to hunt down the truck if you want to buy or return, of course that would depend on your location(large or small town)..i'm not sure of homeowners but businesses could get a payment plan over time on tools and equipment..i remember every my snap-on dealer time stopped in, it was like a candy store on wheels:licking: hard to say no but sometimes.
Slater
I have only purchased the low profile floor jack that they have and it has been awesome!!! (2 Ton Low Profile Floor Service Jack)
I personally would only buy stuff that has good reviews (seems simple enough). I am not much of a risk taker, so products without any reviews are usually ignored by me.
JDgreen
If you are not a risk taker, please use jack stands in addition to that HF floor jack...I am so careful I use a jack stand EVEN when changing a tire and I am not under the vehicle !!!
Slater
Thanks for your concern JD :smile:
I do have Jack stands too (didn't get from HF), but reason for low profile jack was just so I could slide it under my tractor. I only have to jack it up an inch per side to switch my tire sets (so no reason as I never go under the unit and a floor jack would not fit unless I really want to jack up a side.) For winter I prefer a little more "bite" so I use knobby tires and for spring I live in a really wet area so I prefer putting on my turf tires to cover a little more surface area and not rut the turf when mowing or doing other things in the yard :thumbsup:
Jetblast
There's not a rolling floor jack hydraulic piston made that I'd trust with my painfully compressible body parts.
You can run a chainsaw 1000 times with no eye protection, but that 1001th time can be a real buzzkill!
John_in_TN
I have to admit that I have spent a few thousand dollars at Harbor Feight over the past 20+ years. Overall, I am very pleased with my purchases. I am very selective as to what items I purchase from them. They do sell some very low quality items, but they also have some extremely good values in good quality items.
All their "hand tools" now have "lifetime warranties". I have never needed to use this. I generally buy their higher-priced hand tools and impact type sockets. They do tend to fit nuts/bolts a little looser than my craftsman or snap-on wrenches but seem at least as strong as, and actually more comfortable to use than the craftsman. I have never broken an HF wrench. Their better screwdrivers seem to hold up better than my craftsmen drivers.
The only item I have ever returned to them was a defective "long-frame" floor jack. The replacement jack and an identical jack purchased latter are each more than five years old now and both still work flawlessly. The return process was the easiest I have ever experieced - I walked in the store and told the clerk that I had a defective jack outside in my truck. She asked for a description of the jack and the problem. She picked up a phone, had a guy in the back bring out a new jack, rang it up as a "warranty", had the guy help me load it in my truck and bring the old jack back inside (I didn't even have to go back in the store with him). I have witnessed several customers returning the cheap electric power tools, and have never heard a single question asked of that customer, just "lay that one here, and go get a new one".
If I were making a living with these tools, I might prefer more expensive versions of frequently used items. For my purposes, HF is my first choice for most items.
John_in_TN
JDgreen
May not have anything to do with HF tools, but another poster remarked about not getting under his vehicle while it was supported by a jack.
On my JD4210, to install the rear mower draft support links, and attach the PTO driveshaft for the 7-Iron deck, I have to remove the sliding drawbar, raise the 3-point lift arms, then back the rear tires up on a stack of patio blocks about 4 inches high. Only then can I crawl underneath between the rear tires, on my back, and attach the draft arm links and spring clips in the clevises, and slide the PTO driveshaft on. I have NEVER seen anything where the installation was so complex, the dealership obviously uses a hoist to install the decks. If you don't have everything aligned just right, you end up getting out to prop either the mower gauge wheels up or raise or lower the lift linkage. It's a huge PIB that I have to go thru twice a year.
JDgreen
Good post...very informative...:thumbsup:
