May not have anything to do with HF tools, but another poster remarked about not getting under his vehicle while it was supported by a jack.
On my JD4210, to install the rear mower draft support links, and attach the PTO driveshaft for the 7-Iron deck, I have to remove the sliding drawbar, raise the 3-point lift arms, then back the rear tires up on a stack of patio blocks about 4 inches high. Only then can I crawl underneath between the rear tires, on my back, and attach the draft arm links and spring clips in the clevises, and slide the PTO driveshaft on. I have NEVER seen anything where the installation was so complex, the dealership obviously uses a hoist to install the decks. If you don't have everything aligned just right, you end up getting out to prop either the mower gauge wheels up or raise or lower the lift linkage. It's a huge PIB that I have to go thru twice a year.
Wow that does sound like a big pain. Kudos to you for doing it, but I am not sure if I would have the patience :confused2:
