Now you done opened up a whole new thing to argue about.
I think it's cheaper to run a diesel truck
The fuel cost a little bit more but I think I get more miles to the gallon around town pulling a trailer.
Now I do use my dodge ram gas burner most of the time. Does not have the power as the Chevy but it's a lot better ride.
The GM Duramax diesel engine is the best diesel engine on the market over the Cummins and Powerstroke. I know GM guys that are getting around 30 miles to gallon on Duramax w/Allison transmission. That also depends what drivetrain package you have also if your not seeing that 30mpg.
No need for stabilizer in fl. All my mowers work Mon thru Sat yearly ,but to answer your question I have never had a problem linked to not using it nor ethanol ether .
How long is the growing season in your part of Florida? I don't use stabil because of the ethanol I use it for the down time storage during winter.
So the winter is over and there is a full tank of gas in my snowblower. It was supposed to be used up when we got a foot of snow, but the forecast changed at the last minute and we ended up getting only a coating. Last year, I just kept the gas in the tank, and ran it once a month or so over the summer. But this year, should I add stabilizer? I don't want to get into a big debate about whether to drain the tank or add stabilizer, but I do want to know if there is a certain type of fuel stabilizer I should buy.
