Ric
Again it is not about spending the money.
The right tool for the job is the tool that works best for you to do the job the most efficient way.
Some guys use a walk behind edger and some use a stick edger some use a trimmer. What one is the right tool?
Some use a mower lift some use a cherry picker some use a engine hoist. Heck I remember in a thread last year about a guy pushed his mower off his truck onto saw horses.
Man it comes down to everyone has their way of doing things.
I don't adjust valves the way the book says to do it but the out come is the same.
It's not about money? Like I said if you're going to spend 5K what's another $99 to $200 for a tool/ lift designed to do the job safely. I agree some guys use a walk behind edger and some use a stick edger some use a trimmer and the right or correct tool would depend on the job being done. I remember that thread last year about a guy pushed his mower off his truck onto 2x6s on saw horses and he was an idiot and an accident looking to happen. What it comes down to is the fact that everyone thinks they have a better way and knows more about everything than the manufacturer.
The reality is it has everything to do with money because someone would rather spend twenty dollars on a come-along to do the job than a couple of hundred on a lift to do the job right and safely. Reynoldston made a comment that my tool box is bigger then his so he hopes that make you feel better and he would probably be wrong but the tools I have in my tool box are the correct tools for the job I'm doing at the present and 99.9% of the time using the right tool makes the job faster and 100% easier to do.
