opeepingtomo
- Aug 6, 2013
- 16
Does it run fine at full RPMs ?
Put the deck back on and see if it runs better with the pto engaged
I will test more tomorrow. I had the throttle all the way up but did not actually drive it, just idled.
Near the choke assembly there is an adjustment that you can use to increase or decrease the maximum speed it can go. Right now it is just set at how it came from the the factory. Not sure if that could/would have any variable on anything.
I will drive it around a bit tomorrow and then also clean the deck up and reattach it so I can test with the blades engaged.
Thanks again for all of your help.
