davbell22602
Ok skippy here is the deal the model number I gave you is for your mower. That switch your so worried about MTD did not put it there.
Maybe if you have time you can trace the wires and see where they go. I bet the don't go to anything because who ever you got it from took the lights off the mower that the switch went to.
Before you say but the web site does not show the lights that because someone added them at one time.
The lights are built in the key switch. I dont have "P" mower deck. 46in mower deck is a "H". Since when did they put cooling fans on stop and go tranaxles? I always seen cooling fans on hydros.
