How do you deal with ice?
monica123
I am so worried my grandma is gonna fall I am usually seen out there breaking up the ice all the time, what ways do you use to control winter ice?
I use my digging iron to break up the ice (yeah, I know it's not doing my driveway any good), then shovel it away with my snow shovel. This works best on a good sunny day with the snow cleared off first.
Same here, digging iron works great to break up large chunks of ice; just don't hit your toe's with it:thumbdown:
sand, ice scraper, salt(several different types), try some ice cleats on the shoes, maybe use a walker with non slip foots (or create some), maybe install a railing along the most walked area. what i do is shovel/snowblow ANY amounts of snow so that the sun can dry the pavement,if there is no sun then i'll salt/sand the pavement, on heavy amounts of ice i'll bust it up with ice scraper and then i'll think if i REALLY need to be out in the slippery conditions anyway, even to go to work. why chance it, if medicine etc. is needed see if there is a delivery service available....just a few ideas here :smile:
What is the surface you are dealing with ? Concrete, Blacktop, Gravel ????
On a hard surface sometimes putting down sand BEFORE it gets icy will let the ice come up easier. :thumbsup:
My front walk is concrete, as is most of my driveway, the back has a wooden deck. I was told to use non-clumping cat litter for traction, so I am now trying that.
Maybe if you were to put down ice melter before it snows it would prevent any snow or ice biuldup:confused: Has anyone else tried this??
...what ways do you use to control winter ice?
Well monica...:smile:
after about a week of below freezing we are finally above & the sun is cooking off the ice and packed snow... Hope you are having some of the same to get rid of this frozen stuff.... :smile:KennyV
I started another topic recently on salt spredders and that is what I would use. Like someone else said, there are various options for salt. It seems to work pretty well.
We just getting more and more snow covering the ice :( It is horrible to deal with. I keep at it constantly, hopefully I will fins something that works for me.
