Another data point:
I mowed the other day, and set the deck down another quarter inch to 3.5". There was little to no noise or resonance. I'm not saying it's gone 100%, but it was a marked improvement from what it had been.
Reminder, the dealer installed the "kit" from the factory. It helped a little, but still had harmonics and resulting vibrations.
I repositioned the blades and as once before, moving the blades helped significantly.
When the dealer returned the mower after the kit was installed, I noticed they had it set to 3.25, which is lower than I normally mow, so I sat it up the 3.75 and never tried it at the lower setting.
Now it makes me wonder if the kit and adjustments were optimized for 3.25? Could be.
Anyway, kit installed, blades repositioned and set to 3.5 cut, the deck is really pretty quiet. Quiet enough that if it would have been like this from the beginning, I wouldn't have thought twice about it.
One more bit of information, the temperature dropped into the 70's from the 90's on the last mow too.
