ZG222 running hot and sparks at exhaust manifold
leeton31
Any one got an infra red thermometer and a zg222 or zg227 they can take some warmed up operating temperatures of the engine running, i.e exhaust, crankcase, valve covers etc.
Thanks
lugbolt
if the exhaust gaskets are falling apart, that would account for sparks outta the pipe
valve clearance can have an affect too
leeton31
Thanks Lugbolt, all fixed the woodruff key on the flywheel dislodged when I put flywheel back on, so timing was out...that fixed it and I also put new exhaust gaskets on,
so all good. Cheers
Make sure your torque the flywheel down to proper specs. If not this will happen again.
leeton31
Have done Slomo...thanks
