IT is a highly flawed design from the start and both AYP & JD use it
It was just OK on the older models like the LX Deers that had narrower wheels and not this idiot pretend near zero turn steering set up .
There is simply too much load on the bushing , it needs EP bentonite gear grease , not Lithium as specified , but the lack of proper sealing causes the bentonite grease to go off .
The grease nipples rarely seal as they are drilled through the weld by a blind machinist and rarely have any more than 1 turn of thread which does not work with a tapered thread seal .
I have tried just about everything and the only thing that actually worked long term was to drill the end of the Axel for a grease nipple and diagonally cross drill the shaft but thi has to be done every season without fail .
The strait cross drilling ended breaking the axel at the cross drilling
The axel is only induction hardened so lucky to be 0.001" of hardness.
The bush is a powder pressing and is supposed to be partially self lubricating
Every aftermarket parts maker sells the bushes
OEM part numbers
- Ariens21546832
- AYP 532009040, 9040H
- Honda 91051-771-000
- Husqvarna 532009040, 532124959, 539112899, 583670401, 594944401
- John DeereGX10059, M123811
- MTD 135236
- Murray 491334MA
- Toro 114-1640
Now I have been told that this tapered rollers can be made to fit
Stens 230-610 bit you have to make up spacers to fit between the inner cones then shim the wheel so there is no side play
I have not tried it
These 2 full length rollers have worked reasonably well but again I had to make up spacers for different wheels
I use them when the old bushes have under cut the axels .
Stens 230-616
Stens 230-693
