David2291
- Mar 21, 2020
- 1
- 8
I have a 2009 Z225 went to start up a week ago and nothing. Replaced battery and the solenoid and ended up shaving the fuel solenoid down so it wouldn’t be up and started up. How ever after replacing the fuel solenoid the plunger won’t move from the off position. Also when disengaging the brake the mower shuts off. With that I have tested the seat switch and has continuity when the button is depressed. I replaced the small relay that I could see and still nothing. But when I unplug the relay I can release the brake and drive but the blades won’t engage. Any help?
