The model number is in the tittle YTH18542Please do two things for us, so we have a better idea of what you are dealing with. First, post the model number from the ID tag located under the seat. Second, can you post a picture or two of the parts you are talking about. If you use your phone to take the pictures, you will need to resize them smaller before attaching them.
960450056That is the series number. I need numbers under the sear.
I hope this is what you're talking aboutAlso the cable connection point to the left of the brake arm mounting bolt is installed incorrectly the raised nub behind the cable connector L is supposed to be in the slot not behind the bracket. Which will also give you about another inch of tension on the spring to keep the belt tight.
No I am talking about this. Bolt needs loosened and then the bracket slid back to put the nub inside of the slotI hope this is what you're talking about
