YTH18542 deck issue
Randomguy
Also the cable connection point to the left of the brake arm mounting bolt is installed incorrectly the raised nub behind the cable connector L is supposed to be in the slot not behind the bracket. Which will also give you about another inch of tension on the spring to keep the belt tight.
I hope this is what you're talking about
Randomguy
Randomguy
Well that's resolved. I think the previous owner did that because the spring on the other side was broken so I had to replace it.
