Blades X500 big box blades
bckskin2
Will the John Deere blades from the big box store fit my X500 or do I have to buy them from the JD dealer?
Thanks Jerry
Thanks Jerry
Depends on what you are buying at the big box store. Nothing wrong with after market parts.
If you can find the proper blades at the BB stores you should have no problem. I've never seen blades that are the same size and have the same bolt sizes at a BB store. Length, width and thickness are going to be your problem.
Depends upon who made the blades.
I use Oregon & Stens which most of the time are almost identical.
OTOH I have seen a lot of cheap blades that are exactly that, cheap, a little thinner, a little narrower, a little shorter cutting length and God only knows what grade of steel they were made out of.
If there is a brand name stamped into the blade then most likely they will be OK at worst.
If no brand name then best avoided.
