Won't Run on New Gas - Will Run on Carb Cleaner
When you turn the ignition on the pin should fully retract
Off the mower a 9V transistor battery is enough to make it retract
Not sure where we left off.
I pulled the carb twice over the weekend and cleaned the ba-jesus out of it. Confirmed that the solenoid activated with ignition. Got the mower running, urr partly. Will try to link video.
Listen
IMG_2693 by Larry Johnson, on Flickr
