- Nov 29, 2014
- 65
- 24,995
Fish,What model engine is it?
HE put it in his signature 331877 1371-B1.
Larry,
If that engine has a carb solenoid then check it is retracting fully when energised
briggs and stratton 406677, type 0344 E1, code 040927YGWhat model engine is it?
Fish,
Larry,
I believe the internet term would be "LOL"!!Fish,
Larry,
When you turn the ignition on the pin should fully retract
Off the mower a 9V transistor battery is enough to make it retract
When I shut off the key, it revs at normal speed for a few seconds before shutting off.
Compressed air was blown on the outside.How did you clean the carb?
Slomo, Why are you responding to a question that was adressed to me?Compressed air was blown on the outside.
